Activity Forums Adobe Premiere Pro bad voice-over audio
  • bad voice-over audio
    Posted by Fergal Cunningham on April 7, 2008 at 5:05 pm
    Hi all,
    I’m making a quick medical tutorial DVD and the voice-over has been recorded badly, the sound level is too high and at moments the audio meter goes red. It’s not everywhere, just certain words. As I am useless with audio, does anyone know a quick filter to fix this problem? It doesn’t have to be perfect sounding just a bit better.
    Thanks in advance.
    Mike Aurand replied 18 years, 4 months ago 5 Members · 5 Replies
  • Vince Becquiot
    April 7, 2008 at 5:34 pm
    If it’s peaking in the original recording, there is nothing you can really do, the data is lost.
    You can take down the gain at that particular moment, or use the EQ to take down the most offending frequencies, but that’s about it.
    Vince
  • Fergal Cunningham
    April 7, 2008 at 6:36 pm
    I thought there was little to be done alright, guess I’ll mess with the gain a bit. Thank you the advice.
  • Steven L. gotz
    April 8, 2008 at 1:39 am
    Start by normalizing the audio. That might do it the fastest and easiest.
    Steven
    https://www.stevengotz.com
  • Jeff Brown
    April 8, 2008 at 12:52 pm
    You may be able to de-noise and smooth the offending bits via Adobe Soundbooth. I’d work with copies of just the bad segments. It will still sound awful, just not quite as awful.
    -jeff
  • Mike Aurand
    May 9, 2008 at 12:58 am
    If you have Adobe Audition 3 it has a GREAT effect that does wonders for distortion. It’s called Clip Restoration (audio clipping [when the wave squares off]).
    Effects > Restoration > Clip Restoration.
    Set the input attenuation as you want, maybe -2 but set the overhead to 25%, leave the other settings.
