Activity Forums Maxon Cinema 4D bad texture keyframes
  • bad texture keyframes
    Posted by Steve Bentley on August 6, 2017 at 5:46 pm
    Have a look at this and enlighten me as to why some of the keyframes in the texture don’t show up in the Fcurve view. I’ve been pushing keyframes around in time only to find out deep into the project that I haven’t been moving them all. Now I’ve got stragglers down at the 150 frame mark that should have moved up to the 210 mark but I can’t see those ones in the Fcurve view.
    This file only contains a texture.
    Is this normal? Is there a way to make all the channels show in the fcurve view? I even manually twirled every attribute open in the timeline thinking I might not be seeing them if they were nested. The attributes in question just don’t show in this view but automatically populate in the keyframe view. I also tried a bunch of different selection options in the menus (animated, automatic, turned off the links etc)
    11574_badtexture2.zip
    Steve Bentley replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
