Activity Forums Adobe After Effects bad text edges in AE CS3
  • bad text edges in AE CS3
    Posted by Stef Prein on April 9, 2008 at 10:14 am
    I’m working in AE CS3 with som text, but the edges look terrible. The quality is set to best and I can’t find any option for anti-aliasing… It’s not only text form AE itself, but also from PS of AI files… What is going wrong??? Thanks in advance!!
    Stuffy
    student
    Image and Media Technology
    Utrecht School of the Arts
    The Netherlands
    Steve Roberts replied 18 years, 5 months ago 4 Members · 5 Replies
  • Tim Robinson
    April 9, 2008 at 12:44 pm
    It has alot to do with resolution… most fonts just don’t look good high res. I’m sure we need an expert for a more technical fix, but most animators (that knew more than me) that when fonts looked back they would just always do a box blur by only small percentages .2 .5 etc.
    Hope this helps
    Tim Robinson
    tim@erobinsons.com
    Pride-Mobility-Products
    Corporate Video Editor
  • Curious Turtle
    April 9, 2008 at 12:59 pm
    Can you describe your workflow a bit more.
    What are you doing to the text? When does it look terrible (in After Effects? After rendering?)
    A bit more info would be handy :o)
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Steve Roberts
    April 9, 2008 at 1:43 pm
    Does the text look bad in renders viewed with Quicktime Player, or only in the AE comp window?
    Can you switch off pixel aspect ratio correction in the comp window? If that improves it, you can switch it back on — it doesn’t affect renders.
  • Stef Prein
    April 9, 2008 at 3:44 pm
    Thanks for all your replies! The solution is simple. It’s what Steve says about resolution. After Effect, and Photoshop, aren’t very good at rendering out text in 16:9 preview mode. It looks good in rendered files. The problem is the aspect ratio in preview mode.
    Stuffy
    student
    The Netherlands
  • Steve Roberts
    April 9, 2008 at 4:15 pm
    Technically, there is no preview mode in AE — we say “with pixel aspect ratio correction on”. Because it’s always previewing. 😉
    But we’re glad you solved it.
    (Utrecht — nice place)
