Activity Forums Avid Media Composer Bad signal while outputting to mini dv
  • Bad signal while outputting to mini dv
    Posted by Dennis Przywara on January 10, 2007 at 9:48 pm
    I’m outputting a sequence from my avid 4.3 to my Mini Dv Cam. Everyonce in a while, i get a bad signal (blue screen flash) while i’m outputting. I’ve tried changing the cable, but i get the same problem.
    Also, I’ver tried to batch digitize some of the clips from the sequence, but the Avid can’t lock in the timecode to batch. I know the TC is correct, just when the tape is searching for the inpoint, it passes it.
    Any suggestions?
    Dennis Przywara replied 19 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
