bad result with Magic Bullet Looks 2 after rendering in FCP
I’m new here and I’m having a problem with Magic Bullet Looks 2 in Final Cut Pro 7.
I converted the clips previously from H264 from my 7D to ProRes 422 (LT).
I can grade the whole footage perfectly and the preview looks great but when I render it the result is very bad!This image is a screenshot if I klick into the time line before rendering it:
and this image is a screenshot after I rendered it:
First I also used a LUT buddy to add the cinestyle curve on the flat image.
But now I removed this LUT buddy and I’ve still the same problem.Has someone any similar problems or ideas for a solution?
