Activity › Forums › Maxon Cinema 4D › bad render
  • bad render
    Posted by Gon Perdigao on November 4, 2011 at 4:19 pm
    Hi there i’ve made this render, and sometimes the texture get funky, and i don’t know why.
    I’ve render it in net render
    The render settings was :
    Global ilumination :
    General :
    IR+QMC(still image) with the difuse depth of 1 and primary intensity of 100
    Irrandiance cache :
    Stochastic samples : low
    Record intensity :low
    Interpolation method : least squares
    Smothing : weak
    Oversamplig weak
    Irradiance cache :
    Lock – check
    Auto load – check
    Auto save – check
    Ambient Occlusion
    the settings were the generic when you enable it
    Anti-Aliasing :
    Anti-Aliasing: Best
    Filter : still image
    min level : 2X2
    Max level 4X4
    use object properties – check
    MIP Scale : 50%
    Small Fragments : Hybrid
    I also enable the multipass, Ambient Occlusion, Global Ilumination, RGBA Image and Object Buffer.
    The reference is the RGBA Image, cause i render in Net Render and something went wrong and i end up with th B3D files and not with the PNG as i had output it, and the multipass.
    Here is the stills and a render made in after effects in H264, no composition was made
    Link : https://www.sendspace.com/filegroup/4gyfMBlGOD3LCpAZS39EehS9HUNzJD0V
    Gon Perdigao replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
