Activity › Forums › Apple OS X › bad RAM?
  • bad RAM?
    Posted by Brad Bussé on January 31, 2007 at 2:18 am
    A few months back I was having problems with my cursor disappearing and was told that it was probably the USB on my cinema displays causing it. So I stopped using the cinema display usb/firewire hubs and also removed 2 512MB sticks of Kingston value RAM in case it was related to that. I was working on a motion project today that wouldn’t run without more RAM so I reinstalled, and low and behold my cursor is disappearing again. When it disappears, it’s not just invisible, it actually just ceases to exist – moving the mouse around and clicking does nothing. If I restart the Finder that never helps either. I checked the RAM with Techtoo and it checked out okay. Has anyone else experienced this?
    13 replied 19 years, 8 months ago 2 Members · 1 Reply
  • 13 Create COW Profile Image
    13
    January 31, 2007 at 5:48 am
    Bad ram can be the cause of a lot of strange problems. OSX is vary picky on ram I have seen ram that passes the tests that the OS still doesn’t like. Usually its because its cheep ram.
