Activity Forums Adobe After Effects Bad quality in videos when importing to AE
  • Bad quality in videos when importing to AE
    Posted by Hiostt on April 25, 2007 at 3:46 am
    I have filmed my videos with Panasonic DVX100 PAL version, using progressive thin mode. I captured videos with Premiere Pro 2.0 and videos looks good and normal in Premiere. But when I import them to AE 7.0 they are not sharp and they look really bad compared what they look in Premiere. Also the quality is way better when I export video from Premiere than exporting from AE with same settings.
    Examples:
    Shot from premiere: https://koti.tnnet.fi/hiost/p1.jpg
    Shot from AE: https://koti.tnnet.fi/hiost/ae1.jpg
    I have tested all settings in AE’s composition settings page but the quality wont change.
    Also what is the best way to do “miniDV -> DVD” if you use Premiere to capture videos (is it the best way to capture?) and AE to edit and making effects? So that the video dont have any encodes or other things that makes quality worse than the original.
    Thanks for your answers =)
    Hiostt replied 19 years, 5 months ago 2 Members · 2 Replies
  • Peter O’connell
    April 25, 2007 at 3:59 am
    Try right clicking the footage in the project window and choosing Interpret footage>main. Then set separate fields to off (AE mistakenly thinks your footage is interlaced).
    Hope this helps
    Pete O’Connell
    http://www.barxseven.com
  • Hiostt
    April 25, 2007 at 12:43 pm
    In “Fields and Pulldowns” options, “seperate fields” was set to “Lower field First”. I changed it to “off” and now it looks more how it should look, thanks 🙂
    Do you have answer for this:
