Activity Forums Apple Final Cut Pro Legacy Bad Quality Footage Cleanup Suggestions?
  • Bad Quality Footage Cleanup Suggestions?
    Posted by Thomas Morter-laing on January 29, 2012 at 6:09 pm
    Hi guys,
    Probably quite a few posts here about stuff, but hoping for some emergency help if possible- Im dealing with some pretty awfully compressed footage, ripped from a DVD into ProRes 422 (so I have as much space as possible to save what I can)- Its exposed OK, its just pretty mediocre quality. The actual problem comes from the framing of shots, which is…interesting. Because its only for web playback, if it was HD or even good quality SD footage I could crop the shots in a way which presents them better, but as it stands it looks very questionable when I do that. I know there is no magic solution, but in an effort to please the client, I am trying to clean it up after cropping etc- do you guys have any suggestions, tutorials or links which could helps with this? Perhaps some of the advanced tools in Color to sharpen a little etc? As mentioned, it is only for web, so any slight improvement can help. Also regrettably I can’t show any examples because at this stage I’ve been instructed not to show anything for various reasons.
    Cheers!
    Tom Morter-Laing
    Twitter- @TomTheEditor
    _________________________________________________
    Editor, Certified Apple Product Proffessional, 2010
    Equipment (not for ‘bragging’, but in case it’s relevant to future posts :D): Canon 7D, with Rode NTG2.
    iMac 27″ intel i7 3.4GHz, 12GB RAM, ATI HD 6970M [2GB GDDR5], 2x G-Tech G-RAID (0) 2TB over Thunderbolt via Sonnet Echo ExpressCard/34 Thunderbolt adapter and Tempo™ SATA ExpressCard/34. Elgato Turbo H264HD.
    Sascha Engel replied 14 years, 7 months ago 2 Members · 1 Reply
  • Sascha Engel
    January 30, 2012 at 7:04 am
    Without seeing anything, that is quiet a guess work.
    If your footage suffers from lots of grain, try Magic Bullet Denoiser, the best Denoiser out there. It’ll do a brilliant job.
    If you have a lot of artifacting going on, try magic bullet’s Frames Plus: and use the de-artifacting function of it.
