Bad quality final playout
The mpv and Mpegs I use get re-compressed coming into (or out of) Encore even though they have a stable bit rate and were used in other authoring software. The quality seems bad (fields mostly)
I used to render without fields when using DVD Pro and everything seemed fine, even on TV’s. How can I keep the quality and not have to re-transcode or make fields?
Thanks.The Answer is 42.
