Activity › Forums › Apple Final Cut Pro Legacy › Bad Quality export :(
Posted by Senem Ocal on November 11, 2010 at 9:09 amHi everyone…
i finish my editing with final cut pro 7. i saw good quality when playing on timeline. But when i stopped playing the quality getting bad at the freeze frame.
And i cant get qood quality export. I saw the film as freeze frame quality…Do you have any suggestions?
Zak Ray replied 15 years, 10 months ago 3 Members · 12 Replies -
Zak Ray
November 11, 2010 at 8:06 pmWhat format of footage are you working with? What do you mean “it got bad”?
Nicolas Servide
November 21, 2010 at 3:28 pmI get a very similar problem.
The video in the timeline looks fine, but when exporting using ANY METHOD, the image looks jagged.
Also, I cannot export a QT reference. Even it “make movie self-content” is uncheked, the result is the same.
Any thought?
Zak Ray
November 21, 2010 at 10:28 pmAgain, what kind of footage are you working with, and what are your sequence settings?
Nicolas Servide
November 22, 2010 at 10:18 amHi,
I am working with video shot with the codec DVCPRO HD 720p50
You can see the timeline settings in the image.I have tried to export using “QuickTime conversion” and also via Compressor with really bad results.
Actually if I create some text, the letters would look bad as soon as I render the sequence.Ps. Also, I cannot create a QT reference (even when “make movie self-content is unchecked). Is it a known Final Cut bug or is it just me?
Zak Ray
November 22, 2010 at 7:49 pmIf you haven’t rendered your sequence beforehand, this can prevent FCP from creating a reference file (because it has nothing to reference).
I see no image attached.
Nicolas Servide
November 22, 2010 at 7:54 pm -
Nicolas Servide
November 22, 2010 at 7:56 pmOh, I forgot,
I have also tried setting the dominance field to “none”
with no better results… -
Zak Ray
November 22, 2010 at 7:58 pmNot sure why your text is coming out poorly (are you viewing it at 100% or using a broadcast monitor?).
As for the export itself, I’d recommend using QT Movie (not QT Conversion) to get a self-contained file at full quality. Then bring that to Compressor for further compression.
Nicolas Servide
November 22, 2010 at 8:18 pmThanks for the exporting tip.
I am viewing the video at 100% in my iMac.
I just find a way around it, sending the video to MOTION and adding the text there. But it must be a way of doing this in FCP, right?
