Activity Forums VEGAS Pro Bad playback and renders
  • Bad playback and renders
    Posted by Brian Scott on December 26, 2012 at 2:15 pm
    I have seen similar posts but not matching exactly my problem. I am getting issues of “tearing” or garbled previews and also renders. It is related to RAM settings – if I set RAM playback to 0 the problem goes away, but it is tough to edit as the playback is very poor. I am rendering to avi, which has traditionally been Vegas’ strong suit – maybe that has changed.
    I am using the latest build of Vegas, I have and quad core machine with an NVIDIA Quadro FX 4600, 2 RAID arrays – one for video, one to render to. and 16 gig of RAM.
    I did not have any issues with Vegas up to version 9. Since then I have been having issues of various kinds, but this is keeping me from producing product.
    Both AE 6 and Premier 6 run fine on my system, but when it works Vegas is faster to edit on, so I would rather stick with it.
    Any ideas would be appreciated.
    Brian Scott
    President
    Image Design Productions, Inc.
    Mark Barton replied 13 years, 9 months ago 4 Members · 4 Replies
  • Roger Bansemer
    December 26, 2012 at 4:06 pm
    Sometimes I get a tear in the render and sometimes it’s because when Vegas is in the preview/auto mode it just isn’t noticeable that much then when I go back and check my actual event more closely, I’ll see a tear.
    Roger Bansemer
  • Daniel Lee
    December 26, 2012 at 4:44 pm
    Would this be an example of a bad render you have experienced? If so, I have the same problem, and have yet to find a solution. https://www.youtube.com/watch?v=VYU1hHRbKbs at 9:08 and numerous spots after it. It seems to happen a lot when slow motion occurs. Please help?
  • Brian Scott
    December 26, 2012 at 5:31 pm
    No – it is nothing in the originals – I have drop-outs and “garbled” frames. They go away both on preview and on renders when I set the preview RAM to 0
    Brian Scott
    President
  • Mark Barton
    December 26, 2012 at 7:55 pm
    Did you try with the GPU turned off? I was able to render using the GPU for a previous project and on my last one, it kept failing with an estimated render time of about 1hr and 20min. I switched off the GPU and it rendered the file just fine in about 45min. I run a GPU utilization systray icon and that tells me when the GPU is being utilized and I have seen times when Vegas starts to use it, but then it drops to zero. Some of the plugins use GPU independent of VEGAS, so I believe a lot of the GPU related issues are attributed to contention between multiple things trying to use it at the same time and not leaving them in a nice initialized state.
