Activity Forums Maxon Cinema 4D bad mograph student
  • bad mograph student
    Posted by Ronaldo Montalvo on October 22, 2006 at 9:13 pm
    i recently tried to do a simple radio wave concentric expanding circle animation using mograph and utterly failed. (ultimately i ended up just using a simple particle emitter set to scale the centered rings over time as they are emitted which worked OK.)
    with mograph i had tried using a cloner to create the 30 rings and animating the scale. it sort of works and i could produce the overall concentric rings structure with 30 rings but instead of creating the rings one at a time i could only scale the whole clone from 0 up rather than the individual rings produced one at a time and scaling individually. i tried to get the step effector or the delay effector to offset the creation of the cloner rings but wasn’t sucessful.
    i’ve been working with mograph, doing tutorials since number 1, trying to “get it”. i’ve created some really cool things based on the tutorials but this simple real world task stymied me. mylenium good teacher, me bad student. any pointers on how to use mograph to do this simple thing or one of the tutorials i should go back and study more closely?
    Ronaldo Montalvo replied 19 years, 10 months ago 2 Members · 2 Replies
  • Mylenium
    October 23, 2006 at 5:38 am
    Animate the ring as you need and put it in the cloner. Apply a step effector. Turn off the Scale parameter and instead on the “Other” rolldown activate Time Offset. I’ve put together a quick example using the torus object, but you can of course also use a SweepNurps if you need different shapes. Download it here:
    Click me
    Mylenium
    [Pour Myl
  • Ronaldo Montalvo
    October 23, 2006 at 10:16 pm
    thank you very much for taking the time to post that. i was missing the time offset in the other menu of the step effector. i get it now, (at least that part). it’s a simple solution with much more control than through the particle emitter of the end radii/sizes of the rings. looking forward to your continuing tutorials. in spite of my failure with this little problem they are very helpful and informative. thanks again mylenium.
