Activity Forums VEGAS Pro Bad Mic Audio needs to be corrected. Any Advice?
  • Bad Mic Audio needs to be corrected. Any Advice?
    Posted by Gabriel Solomon on March 18, 2013 at 6:40 pm
    I had a problem with my wireless microphone on a job. I have sound forge and am trying to correct the problem. You can hear the problem on the attached file. I need to get rid of the squeak sound in the background of the lefty channel audio. I was recording from the camera microphone on the right channel and the wireless mic on the left channel. Can anyone suggest what steps I should take to correct this in Sound forge and then bring the file back into sony vegas.
    I need to get rid of the squeak sound in the background of the left channel audio. I was recording from the camera microphone on the right channel and the wireless mic on the left channel.
    The right channel camera mic is not bad, but in theory the left channel wireless mic can be much better if not for the squeaking noise.
    I posted a small sample clip of the problem. here is the link.
    https://f1.creativecow.net/5661/5661#5662
    Gabriel Solomon
    LifeCapture Images
    http://www.lifecaptureimages.com
    Larry Brewer replied 13 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    March 18, 2013 at 7:30 pm
    OOh, that’s nasty . . ..
    I’m giving it a go in iZo . . .
    Grazie
  • Larry Brewer
    March 18, 2013 at 8:25 pm
    I used Audacity and ran the wav file through 3 times with the default settings. The result was very clean. Mix in a little right channel for ambiance and not too bad. I’ve attached the “fixed” file. Again, it is so clean as to sound unnatural. It will be necessary to mix your ambient mic to get a more natural sound.
    BTW. The right channel is pretty OK the way it is for my taste.
    5668_5661badaudiosamplefixed.wav.zip
  • Roger Bansemer
    March 18, 2013 at 8:31 pm
    I gave it a quick try here.
    Roger Bansemer
  • Roger Bansemer
    March 18, 2013 at 8:41 pm
    Here’s a try at an audio fix.
    5672_vegassoundtestfix.zip
    Roger Bansemer
  • Larry Brewer
    March 18, 2013 at 8:53 pm
    You did get rid of the squeal, but it seems that there is an annoying artifact remaining. Again, maybe not so bad if mixed with the audio from the original camera mic. What audio processing did you use?
  • Gabriel Solomon
    March 18, 2013 at 8:57 pm
    Larry, Thsnk you. It sounds great. How did you get rid of the squealing. I do not have audacity. I am sure I can figure it out, or apply the technique to sound forge
    Gabriel Solomon
    LifeCapture Images
  • Gabriel Solomon
    March 18, 2013 at 8:58 pm
    Hi Roger, good job
    what software did you use. What was the process you used to acheive the result. I have many clips with a similar problem
    Gabriel Solomon
    LifeCapture Images
  • Roger Bansemer
    March 18, 2013 at 9:18 pm
    I put it in iZotope. Probably could do better if I took more time with it. And I’m not all that good with the program.
    I mainly used the denoise funtion but I also went in with the paint brush to eliminate all those plosives.
    Roger Bansemer
  • Larry Brewer
    March 18, 2013 at 9:33 pm
    Audacity is a freebie. I used noise removal effect in Audacity. You can find it and download it. Pretty simple to use.. after you figure out how to use it. (but isn’t everything). There are other similar programs. Pro Tools is probably the best. Several tutorials on YouTube. If the total program Isn’t too long and the file isn’t too large, just upload the whole thing. Be happy to run it through and send it back to you. No guarantees though…
