Activity › Forums › Panasonic Cameras › Bad looking footage
  • Bad looking footage
    Posted by Pete on March 27, 2007 at 2:54 am
    My apologies i posted this message in FCP forum not knowing there was a DVX-100a forum:
    Hey guys, I’m doing, and editing favor for a friend of mine (FREE, yes FREE), and I’m editing or helping to edit a short film, the film was shot on a panasonic DVX-100A @ 24p so i went ahead and setup a capture preset @ 24fps (not sure if this was right to begin with), but I burned a DVD, and it looks like crap when i export it, and when i burned the DVD is even worst on the TV.
    Basically it looks like a field craziness, and the the motion on the scenes looks stroby, like is missing something.
    when I first started digitizing the footage, i remembered that the footage looked great but i was having problems with the audio, it was behind, so i figured it was some sort of frame rate issue, which when i changed the profile to the 24fps, it worked fine, but now it just looks terrible, and it doesn’t look that bad on screen.
    I just realized that maybe i should have digitized using the 59.xx setting is this correct?
    What’s the problem.
    Also does it matter that we used a different camera that does not play 24fps to digitize? I mean this was shot using the Panasonic, but we digitized from a regular DV camera used it as a deck, could this be the problem, what’s the ideal setting for this project?
    As always thans in advance, you guys are all great.
    Pete replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
