Activity › Forums › Maxon Cinema 4D › Bad lighting on textures?
  • Bad lighting on textures?
    Posted by Adam Lincoln on November 17, 2016 at 12:27 pm
    Hi all,
    I’m a bit stumped.. Does anyone know why I’m getting weird shadows and texture seams when adding different lights to my model? The textures should line up.. I’m guessing it has something to do with the Normals map because it sorts itself out when I disable it. I’ve added a couple of screen shots if this helps.
    I’m using C4D R17
    Thanks in advance. ?
    Adam Trachtenberg replied 9 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 17, 2016 at 3:45 pm
    Where did you get the textures? Normal maps can be a little complicated. There are a number of types (Object, World, Tangent) and different formats (all the check boxes in the Normals Channel). Generally speaking you need a tangent-type map of your object is going to be deforming.
    From the help file:
    The following rule of thumb applies to the most common method, Tangent:
    • If the Normal texture is mostly light green, activate Swap Y & Z (Y up).
    • If the Normal texture is mostly light blue, deactivate Swap Y & Z (Y up).
