Activity Forums Apple Final Cut Pro Bad graphic quality after render
  • Bad graphic quality after render
    Posted by Brandon Adam on January 5, 2015 at 4:17 am
    Hello,
    I am editing some video in FCPX with some graphic overlay (made in AE). They look great in comp and rendered from AME but turn out horrible when viewing and exporting them in FCPX. There seems to be a black shade/outline visible over the text (see example). I’m not sure what’s causing the issue.
    AE settings:
    Comp 1280X720 25fps
    AME
    720X576i (for DVD) Pro Res 4444 alpha
    Thank you.
    Michael W. towe replied 11 years, 8 months ago 3 Members · 6 Replies
  • Marco Feil
    January 5, 2015 at 11:47 am
    Check if the alpha is interpreted right (video inspector – info – settings – alpha handling) and set it to the same as in the AE export. IIRC it should be premultiplied but FCPX sometimes interprets it as straight alpha.
  • Brandon Adam
    January 6, 2015 at 4:02 am
    Thank you for the reply.
    I have gone through the steps but I can’t seem to find the ‘alpha handling’ section. Video inspector shown below.
    Thank you.
  • Marco Feil
    January 6, 2015 at 8:48 am
    The settings option is in the drop-down menu at the bottom left of the inspector where you can select the metadata view, in your screenshot it says ‘basic’.
  • Michael W. towe
    January 6, 2015 at 5:51 pm
    The problem here is that ProRes4444 doesn’t recognize alpha correctly. You are getting that black because it was most likely rendered with a “Premultiplied” alpha channel. You need to switch it to a “Straight” alpha channel. However if you have done this and rendered to ProRes4444 you will still get that black, because ProRes4444 doesn’t recognize the Straight alpha.
    So what’s the solution? Render to the Lossless codec with “Straight” alpha. You will need to render after import, but the alpha will be correct and the black will be gone.
    Michael W. Towe
    President M2 Digital Post
    http://www.m2digitalpost.com
  • Brandon Adam
    January 7, 2015 at 4:25 am
    [Michael W. Towe] “So what’s the solution? Render to the Lossless codec with “Straight” alpha. You will need to render after import, but the alpha will be correct and the black will be gone.
    I used Animation, which seemed to work. Are there any other alpha channels with a “Straight” alpha?
  • Michael W. towe
    January 7, 2015 at 3:41 pm
    To be honest I am not sure since I have been using Animation. Maybe Avid DNxHD?
    Mike
    Michael W. Towe
