Activity Forums Adobe After Effects Bad Footage!!
  • Bad Footage!!
    Posted by Fame Little on January 16, 2007 at 4:56 am
    Hi All, I shot some footage with the JVC HD100 in DV mode 24p wide then imported into AE 7 it came in at 29.97 even after I set the preference to 24 in the import settings but now you can see the jagged fields in the footage. I tried to use lower field in the interpret footage panel also changing it to 24, 23.98 and selecting none for fields but still showing jagged fields.
    Thanks.
    Fame Little replied 19 years, 8 months ago 3 Members · 3 Replies
  • Andrew Kramer
    January 16, 2007 at 5:05 am
    search for 2:3 pulldown. Try using the guess pulldown option. depending on how it was shot you may try the 24pa option as well.
    Andrew Kramer
  • Serge Hamad
    January 16, 2007 at 5:14 am
    Your camera has been addind a 2:3 pulldown. Let AE guess wich one it is in the footage interpretation window.
    Salut.
    Serge
    “InvigoMany” On sale here:https://www.nyc-visual.com
  • Fame Little
    January 17, 2007 at 4:12 am
    Thanks guys I’ll try that
