Activity Forums Avid Media Composer Bad exports to Sorenson
  • Bad exports to Sorenson
    Posted by Michael Brown on June 16, 2006 at 12:29 pm
    Running Adrenaline 2.1.8
    3 video layers:
    V3: some lower third animations
    V2: video with animatte masks, some color correction
    V1: video with color corrections
    Problem: QT reference export to Sorenson then to MP2 results in changing video levels before and after every transition. For that matter, ANY exported media, .avi, .wmv, shows the same problem. I’ve tried eliminating one track at a time, but the problem still shows up.
    All effects have been rendered in to out before exporting.
    Interestingly, everything plays well and looks great via analog component & composite out. (I actually had to lay off to tape and re-capture as one video track to finish the job.)
    I appreciate any ideas about where to look next.
    Mike Brown
    Video/Film Producer
    American Heart Association
    Michael Brown replied 20 years, 3 months ago 2 Members · 2 Replies
  • Jon Zanone
    June 19, 2006 at 11:54 am
    I don’t know if this is will help, but I had a really weird shift in Xpress Pro when using lower thirds. It would compress the entire frame horizontally during the time the graphic was up. I finally found that a mixdown solved the problem (or placing a submaster where I wanted the graphic and stepping into that to create my lower third. This actually showed up on the analog out as well….
    HTH,
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Michael Brown
    June 20, 2006 at 12:18 pm
    Settings > Media Creation > Render Tab
    Cleared the “Same as source” check box.
    Some of the underlying material was DV25, causing setup to go up & down, among other things.
    All is well.
    Mike Brown
    Video/Film Producer
