Bad Clip from Canon 60d
I shot a wedding, and one certain clip comes into premiere with no audio and freezes and crashes premiere everytime it hits a certain point. I tried to nest the clip and export it using “match settings” preference…and the the clip exported, then turned totally red after the same point it was freezing at before. I can watch the original clip JUST FINE in quicktime player…audio and all. This is coming from a Canon 60d 29.97, 1920×1080. Has anyone seen this, and have a solution. Its an important speech from a wedding, and I need to be able to use it. Thanks!
