Activity Forums Panasonic Cameras Bad Battery?
  • Bad Battery?
    Posted by D. scott Dobbie on December 14, 2007 at 10:01 pm
    Have the HVX200 and 2 regular Panasonic batteries. Putting one battery on the charger a couple days ago, the red light came on (indicating power), but the green light, which is normally steady once the battery is attached, started to flash about once every second. I tried re-seating the battery, but the light continued to flash. I went away to do something and came back 10 minutes later and saw the light had turned to solid green, indicating it was charging properly, so I left it alone. Several hours later I happened to notice only the green light went out, indicating the battery was fully charged.
    I then used the battery yesterday, and it died after only 15 minutes. Normally I can go for 2-3 hours with these. Fortunately my other battery was fine and the shoot went without any glitches.
    Interestingly, when I put the first battery in the camera, the little indicator didn’t show that the battery had a full charge – looked like 80% or so, but certainly not 10%, which is about all the juice I got.
    Is this a bad battery? Is there another explanation?
    -Scott
    D. scott Dobbie replied 18 years, 8 months ago 4 Members · 6 Replies
  • Richard Harrington
    December 14, 2007 at 10:57 pm
    Bad Battery…. or gremlins…
  • D. scott Dobbie
    December 17, 2007 at 3:47 am
    Thanks Richard. You’re the only one who weighed in, so I won’t waste my time trying to charge it again. Samy’s Camera tomorrow for two new ones.
    Best,
    -S.
  • Dana Lavoie
    December 17, 2007 at 8:13 pm
    same thing just happen to me
    but all i want to know is how you reset the battery?
  • D. scott Dobbie
    December 18, 2007 at 4:48 am
    I’ve never heard of resetting the battery. Possibly charging it overnight and then depleting it completely a couple times. I don’t know.
    I purchased two new ones today. Not happy at all that the Panasonic one lasted just over a year – so I bought a couple by Lenmar that have a 3-yr. warranty and were only $99 each (vs. $175 or so for the Panny’s). They were highly recommended by Samy’s, otherwise I wouldn’t have taken the risk.
  • David Donnenfield
    December 18, 2007 at 7:49 pm
    I just bought two of these for $79 each, based on user comments on the DVXUser forum. Worth researching.
    https://www.dvxuser.com/articles/battery/
  • D. scott Dobbie
    December 19, 2007 at 1:47 am
    Good to know for future reference. The Lenmar’s are 5400 mAh, so I’m not too far off from that. Knowing DVXUser sponsored this other battery gives me confidence, even though I don’t know who the manufacturer is.
