Bad audio with MPEG or AVI
Posted by Jimdevo on January 29, 2006 at 2:40 amWhen I render my video to MPEG1 or even an AVI the audio sounds over modulated and there is distortion. However, it sounds great on the timeline before rendering. Perhaps I have the settings out of whack? “Include audio stream” box is checked under the audio tab. Sound familiar anyone? Can’t figure this one out. Research didn’t help. My destination for this video is the web, specifically youtube.com which is hosting the video for an ebay ad.
JimJimdevo replied 20 years, 8 months ago 3 Members · 7 Replies -
Gary Kleiner
January 29, 2006 at 6:07 amAre you rendering to a new track, then playing back both the original and the new one?
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Jimdevo
January 29, 2006 at 6:21 amNo I am rendering my timeline to the hard drive as a MPEG1 or AVI. Should I render it to a new track?
Gary Kleiner
January 29, 2006 at 6:50 am[jimdevo] “Should I render it to a new track?”
No, not to address this particular problem.
Gary Kleiner
Seth Bloombaum
January 29, 2006 at 7:12 pmWhen I render my video to MPEG1 or even an AVI the audio sounds over modulated and there is distortion. However, it sounds great on the timeline…
Perhaps you’re already aware of this, but your post doesn’t make it clear. Sounding great on the timeline is not enough. It also needs to not exceed 0db on the master meters in the mixer panel. Most people would say not to exceed somewhere between -3db and -0.3, to provide some margin of safety.
Jimdevo
January 29, 2006 at 10:17 pmSo what’s happening is the audio of the rendered file sounds bad when played outside of Vegas. But when the rendered file is played in Vegas, it sounds great. What I mean by “sounds bad” is it sounds distorted or scratchy. Very bad quality from the original.The audio meters do not exceed 0db. I am experienced at Mpeg2, but I’m trying to put this video on the web in either Mpeg or AVI and can’t believe it’s supposed to sound this bad. When put in DVDA as an mpeg2 it sounds great. Has no one had audio problems with an mpeg1? Or is the audio quality that far off from the original sound. It just seems like it’s being over compressed or something.
Jim -
Seth Bloombaum
January 31, 2006 at 5:09 pmWell, that’s odd. Seems to indicate a problem with whatever player you’re using outside of Vegas. Is it possible that the EQ has been set up in Windows Media Player… I’d try zeroing that EQ, but that’s really just a wild guess.
I do think you should try this file on other computers.
Nothing wrong with MPEG1 audio. Not great, but OK. Not a good choice for web distribution, though, as it won’t stream or progressive download, and all the true streaming formats look better than it does for a given data rate. (that would be windows media, quicktime, and realmedia). MPEG1 doesn’t get much use anymore except as the VCD standard, which remains very popular in Europe and Asia. Not for web.
Are you using a standard rendering template? If you’ve modified the audio encoding it’s possible that an external player doesn’t have the right audio codec, or correct playback for a particular audio bitrate. If you’re set on MPEG1 for some reason, I’d try another render using a standard rendering template.
Jimdevo
February 3, 2006 at 3:05 amHey thanks for the help. Sure enough it was Windows Media Player. That explains why the file played well in Vegas. Thanks!
