Activity Forums Adobe After Effects Expressions Bacteria -animating position at fixed intervals with not so fixed values
  • Bacteria -animating position at fixed intervals with not so fixed values
    Posted by Corrado Carlevaro on July 30, 2010 at 2:40 pm
    I need an expression as the one posted in “animating position at fixed intervals with fixed values” but with a bit of randomness in position values: moving a layer about 5 points up, pause for 2 seconds, up again and so on.
    This is the expression Dan wrote:
    moveTime = .3;
    holdTime = 4.7;
    delta = [0,-5];
    seg = Math.floor(time/(moveTime+holdTime));
    t = time % (moveTime+holdTime);
    value + delta*seg + linear(t,holdTime,holdTime+moveTime,0,delta)
    I’d like to add some randomness to the position value (-5), but if I put a random number there (delta=[0,random(-4,-6)]) the randomness is increasing over time and the layer is not fixed during holdTime.
    Any idea?
    thanks in advance
    Corrado Carlevaro
    Corrado Carlevaro replied 16 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    July 30, 2010 at 3:58 pm
    Try it this way:
    moveTime = .3;
    holdTime = 4.7;
    minDelta = [0,-4];
    maxDelta = [0,-6];
    seedRandom(index,true);
    prevDelta = [0,0];
    for (i = 0; i < seg; i++) prevDelta += random(minDelta,maxDelta);
    delta = random(minDelta,maxDelta);
    value + prevDelta + linear(t,holdTime,holdTime+moveTime,0,delta)
    Dan
  • Corrado Carlevaro
    July 31, 2010 at 10:04 am
    Great, and just after one hour!
    Corrado Carlevaro
