Activity › Forums › Compression Techniques › Backwards Frame Size
  • Backwards Frame Size
    Posted by Tyler M. on July 16, 2010 at 3:28 pm
    I’ve never had to export anything with a weird aspect ratio but I’m converting a .wmv file to .mov and the aspect ratio is 720×1280. I’m using an HDV720 preset in compressor with flip4mac and turning on 100% of source for my frame size but it comes out backwards (1280×720). I then entered the frame size myself (720×1280) using customs settings and the same issue occurred. Pixel aspect is set to square. What am I missing or is it a quicktime issue? Thanks.
    Daniel Low replied 16 years, 2 months ago 2 Members · 5 Replies
  • Daniel Low
    July 16, 2010 at 4:47 pm
    [Tyler Mleynek] “I’m using an HDV720 preset in compressor”
    That preset does 1280×720. HDV is not capable of doing 720×1280
    Why do you want 720×1280?
    Sent from my iPad Nano.
  • Tyler M.
    July 16, 2010 at 6:40 pm
    Because I’m converting a video that is 720×1280 from wmv to mov. The video was made with that frame size.
  • Daniel Low
    July 16, 2010 at 7:52 pm
    I’d go for a .mov and use the photoJpeg codec.
  • Tyler M.
    July 16, 2010 at 9:38 pm
    That was it. Thank you friend. Is there a website or book that I can learn more about codecs? Thanks again.
  • Daniel Low
    July 16, 2010 at 10:21 pm
    For stuff like this…..no for everything else the https://WWW is the best book in the world.
