Activity Forums Apple Final Cut Pro Legacy Backwards Compatible Logging Data?
  • Backwards Compatible Logging Data?
    Posted by Tareco Pictures on July 21, 2005 at 9:20 pm
    Our Edit System: G5 Dual 2.5 w/4GB RAM, OS 10.4.2, AJA Kona2 w/1.1.2 Driver, ADTX RAID, FCP5.0.2
    A recent problem capturing 23.98 HDCAM clips to 23.98 DVCProHD resulted in bad audio sync; the issue is with the Kona2. All we came away with successfully from those capture sessions was the logging data, because most of the clips were 1-4 frames off sync.
    AJA says they are working on this problem and eventually we can capture to DVCProHD in FCP5 in Tiger, but they cannot say when a fix will come. Their current solution is to dump out FCP5, install FCP4.5, recapture all the clips, then upgrade the project to FCP5 to proceed with editing. They tested this and it worked– but they initiated their test in FCP4.5, then upgraded to FCP5.
    We have a long and relentless schedule ahead for editing our indie movies, so we need to try this FCP4.5 solution. Problem is, we have more than 50 reels of clip logging data in the FCP5 project, and that project will not open in FCP4.5 (we tried it on a separate system). We cannot afford an extended rental of an HDCAM deck for experimentation, so we need to know– is there a way to ENSURE we can bring our bins of offline clips from our FCP5 project into an FCP4.5 project?
    Jerry Hofmann replied 21 years, 2 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    July 22, 2005 at 1:28 am
    Absolutely.
    Select all clips in your FCP 5 project file, and then choose file/export/batch list… open that file in FCP 4.5 and you should be good to go.
    Jerry
  • Gary Adcock
    July 22, 2005 at 2:07 am
    [tareco pictures] “s there a way to ENSURE we can bring our bins of offline clips from our FCP5 project into an FCP4.5 project?”
    XML export ( use version 1)
    gary adcock
    Studio37
    HD and Film Consultation
  • Tareco Pictures
    July 22, 2005 at 7:46 am
    Thanks for the batch list suggestion… here’s the result:
    I exported a batch list from an FCP5 bin full of offline clips, but in another machine’s FCP4.5 it would not open or import; it said there was an error and could not read the file. Then I tried exporting an FCP5 batch list from a group of offline clips selected individually (not from a pre-existing bin) and that didn’t work either.
    Please see the response from Mr. Adcock about exporting as XML version 1– this method did import successfully to FCP4.5 from FCP5, although we have not tried to capture yet.
  • Tareco Pictures
    July 22, 2005 at 7:51 am
    I exported as XML version 1 an FCP5 bin full of offline clips, then opened that XML file in another machine’s FCP4.5 and the bin appeared successfully in a browser. We cannot try and capture until we rent an HDCAM deck next week, but this sure looks like a good result.
    Thanks for the info…
  • Jerry Hofmann
    July 23, 2005 at 1:23 pm
    Probably some column header in 5 caused the error… didn’t think of this… XML data will work though…
    Jerry
