Activity Forums Avid Media Composer Backward compatible sequences?
  • Backward compatible sequences?
    Posted by Eli Brown on December 27, 2012 at 2:24 pm
    I have a job coming from an Avid MC 5.5 and am wondering if there is a way to do a color grade in resolve and then reconform it without having MC5.5 on my system. I have MC6, so I was planning on opening their earlier version sequence and exporting the AAF to Resolve and roundtripping back to MC6… but then, how to get that sequence back to MC 5.5? Thanks in advance for any ideas!
    Eli
    • postbrooklyn •
    creative. post. production
    @postbrooklyn
    Eli Brown replied 13 years, 8 months ago 4 Members · 4 Replies
  • Michael Phillips
    December 27, 2012 at 9:24 pm
    The rendered MXF media is compatible, and you can open sequences in earlier versions but it depends on if you are using something in v6 or later that is not available in 5.5. For the most part, I think you’re good.
    Michael
  • Neil Patience
    December 27, 2012 at 9:26 pm
    Hi Eli
    Avid 5.5 can read Avid 6 projects with the limitation that if you use a MC6 feature that is not in 5.5 this will not translate.
    I found this thread where several people confirm this.
    https://forums.creativecow.net/thread/45/883647
    best wishes
    Neil
    http://www.patience.tv
  • Pat Horridge
    December 28, 2012 at 10:17 am
    Yes backwards compatability is still pretty robust despite the many recent developments. We have a lot of V5.5 to V6 & V6.5 projects moving around.
    As always best to recreate a fresh project with the version of MC you are on and copy just the bins you need. Yes MXF media is compatible so if you have an effect thats not backwards supported just mix it down.
    This is one of the reasons I’m so pleased Avid have resisted the easier “x” route of completely redesigning the software and breaking that compatability model they’ve protected for so long.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Eli Brown
    December 28, 2012 at 1:28 pm
    Thanks for the info! Glad to hear it works that way.
    • postbrooklyn •
    @postbrooklyn
