Activity Forums Apple Final Cut Pro Legacy Backward Compatibilty
  • Backward Compatibilty
    Posted by Gsp on August 2, 2006 at 2:52 pm
    Is there a way to take a FCP 5.1.1 project and make it a FCP 5.0.4 project so that someone with and older version can open it? Thanks for the help, can’t find anything posted anywhere.
    Issimo replied 20 years, 1 month ago 4 Members · 3 Replies
  • Terry Jones
    August 2, 2006 at 3:24 pm
    Hi There,
    You can export the 5.1.1 project as an XML file and import it into 5.0.4.
    I did this exact thing last week and it worked fine.
    Good Luck
    Terry
  • David Geist
    August 2, 2006 at 5:36 pm
    How about from 5.0.4 to 4.5?
  • Issimo
    August 3, 2006 at 2:47 am
    I have used this XML work-around with FCP 5 to 4.5 with XML version 1. I have upgraded a Dual 1.8 GHz G5 to FCP 5.1 and exported an XML to a Dual G5 2.7 GHz with FCP 5.0.4. When I try to import the XML file, I get this message:
    “XML Translation was aborted due to a critial error.”
    I have tried exporting just the sequence and the entire project file as XML, but neither work. I have tried XML version 1 and 2.
    Do you have any suggestions?
    Thank you,
    issimo
    “Ci vediamo, e se non ci vediamo, accendiamo la luce.”
