Activity Forums Adobe After Effects Backup Hard Drive
  • Backup Hard Drive
    Posted by Jerry Smith on November 20, 2015 at 9:48 am
    So, suppose you have an AE project and it is in Projects/AE/ and it references footage (music) that is in Projects/Music/
    Then suppose you back up the Projects folder by copying it to a backup hard drive. What music does the backed up project reference? The original? Or the copied?
    John Cuevas replied 10 years, 9 months ago 2 Members · 1 Reply
  • John Cuevas
    November 20, 2015 at 12:41 pm
    if you use the the File > Collect Files command, a new .aep will reference the copied files. If you need it to reference the copied file and it isn’t just right click the audio file in the project window and select replace footage.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
