Activity Forums Adobe After Effects Back/Rim lighting?
  • Back/Rim lighting?
    Posted by Dale Kutzera on June 2, 2012 at 12:17 am
    Is there a way to simulate a back rim light when lighting a character? I have a figure green-screened into a background and can use a spot to adjust front lighting, but was wondering if there is a way to add a kicker. I have tried placing a spot behind the character, but as it is only 2-D, there is no surface for the light to hit.
    Dale Kutzera replied 14 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    June 2, 2012 at 1:32 am
    Check out this Light Wrap tutorial by Andrew Davis. You should be able to modify his technique to create your rim light.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dale Kutzera
    June 2, 2012 at 2:17 am
    Thanks. Huge Help!
