Activity › Forums › Apple Final Cut Pro Legacy › Backing up Final Cut Pro Document to External hard drive
  • Backing up Final Cut Pro Document to External hard drive
    Posted by Noah Aust on August 10, 2010 at 5:31 pm
    I’m working on a video project. When I began the project, I didn’t have access to an external firewire hard drive, so I set the scratch disk as the boot drive.
    Now I have access to an external firewire hard drive, and I’d like to back up my movie. I’m still editing it, and I don’t know the best way to go about backing up my files to the external hard drive.
    Should I set a new scratch disk now that I’m halfway through the project? What’s the most secure way to keep a copy of the movie on both hard drives?
    Chris Tompkins replied 16 years, 1 month ago 2 Members · 3 Replies
  • Chris Tompkins
    August 10, 2010 at 10:35 pm
    Well, first off, you should never use your boot drive to capture media – ur just asking for trouble.
    Drag the capture scratch folder to the fw drive. Delete the files off the boot drive. Reset scratch.
    Re-link media in project.
    Get another FW drive and back up movie files to it by dragging over the capture scratch folder nightly.
    Chris Tompkins
    Video Atlanta
  • Noah Aust
    August 11, 2010 at 11:55 pm
    Is the capture scratch the only folder I need to drag over to the fw hard drive? That is, can I leave the render file folders and cache file folders on the boot drive?
  • Chris Tompkins
    August 12, 2010 at 8:17 pm
    Delete the renders off the boot drive.
    Reset scratch drive.
    re-render.
    Chris Tompkins
    Video Atlanta
