Activity › Forums › Apple Final Cut Pro Legacy › Backing up a series
  • Backing up a series
    Posted by Jon Smitherton on November 5, 2009 at 3:46 am
    I’m just finishing a 13 part series and am about to archive, so am just wanting to make sure I do everything correctly.
    The series has the studio record captured via digibeta to prores, inserts shot on EX1 HDCam, and have motion projects and a few subcomps (of which I save the source material on another video layer).
    Are there problems with motion projects and the subcomps when using the Media Manager? I have spoken with the producer, who says the original source material would not be used again, but would be good to recall the cut for future series – so hence I want to be careful, especially with the XDCam material.
    The series once aired, will be backed up to Exabyte tape, then I can upgrade the suite to Snow Leopard, and reconfigure the raid of which we have added another drive. I’m going to MM to this drive in the interim, so I can unmount the raid to test if MM has worked properly.
    Jon.
    Jon Smitherton replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
