Activity Forums DaVinci Resolve Backing resolve projects up
  • Backing resolve projects up
    Posted by Adam Jenns on February 27, 2014 at 11:38 am
    Could anyone tell me if there is any way to back a Resolve project up including all the media used, much like media managing a project in FCP?
    Thanks, adam
    Mainframe
    Margus Voll replied 12 years, 6 months ago 5 Members · 4 Replies
  • Joseph Owens
    February 27, 2014 at 4:23 pm
    Not that Media Mangler is all that great to start with…
    You can export the project under File… Export Project and include reference stills, etc. but creating a Media folder isn’t part of that operation, and not particularly useful, unless you are starting a project with a “dailies” pass prior to an edit lock. There are more efficient ways to consolidate source media given that Resolve is primarily designed to access folders wherever it is directed to draw source media, and then render color-corrected images to a target directory. There is a kind of File Management protocol in its export/delivery interface, but this is not the same as either a Final Cut Media Manage or an AVID Consolidate.
    In the case of the dailies workflow… I can’t see the advantage of exporting the project at all, since the grades associated with the source media will be irrelevant to the rendered files — and if you are anticipating a re-conform, then all you need is a ColorTrace, and the media had better be where you left it.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Robert Due
    February 27, 2014 at 4:55 pm
    This may be of some use for you…
    https://www.niwa.nu/resolve-collect/
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
    DaVinci Resolve 10.1.1
    OSX 10.8.4
    MacPro 8-core 4,1 2.93 Ghz
    24GB RAM
    Nvidia GT120 GUI
    Cubix Expander with 2 x GTX570 (CUDA 5.0.36)
    Decklink Extreme3D+
    Panny BT-LH1710P/ Panny TH-42BT300U
    Tangent Wave
  • Chris Martin
    February 28, 2014 at 4:46 pm
    I usually just bring into the media pool the select media which makes it easy to use copy manager to copy media as a backup if needed. For the most part I just backup the project and use edls to retrieve from production drives if the need arises.
  • Margus Voll
    March 1, 2014 at 9:42 am
    If we could trim all the media like RED then it would bee good option.
    Specially with the ones that have frames from the camera.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
