Activity › Forums › Maxon Cinema 4D › background pass?
background pass?
Posted by Manojit Ghose on January 10, 2013 at 12:12 pmis there a way to get the background as a multilapass pass?
thanks
m.Manojit Ghose replied 13 years, 8 months ago 2 Members · 2 Replies -
Adam Trachtenberg
January 10, 2013 at 2:25 pmNo, but you can simply render an alpha and then load your BG footage as a layer in your compoositing application.
Manojit Ghose
January 10, 2013 at 3:01 pmi was looking for checking the splits together in the “multi-pass” layers section vis-a-vis the beauty within the picture viewer.
now when i look at the multi-pass it shows my object on a black BG – it would be great to have the BG as well to compare it with the RGB – (especially the edges).thanks
m.MG
