Activity Forums Maxon Cinema 4D Background object in RedShift/Octane
  • Background object in RedShift/Octane
    Posted by Alex Anderson on April 27, 2018 at 5:32 pm
    i have downloaded redshift/octane demo [watermarks] for c4d, and tried few simple things , its great BUT i tried one simple motion tracked video and try put object in it Now problem is i can’t render the background [video], any help to solve this ? usually standard render i create background object and attach my video in color channel.
    Learn..Learn..Learn
    Karl Smith replied 7 years, 5 months ago 3 Members · 4 Replies
  • Rick Moore
    June 16, 2018 at 3:03 am
    Wow, I’ve been searching and searching or an answer to this as well.
    Let me know if you or if anyone can give some advice on this. I’ve spent hours on a model in octane and now can’t believe that this may not be feasible.
  • Alex Anderson
    June 20, 2018 at 10:49 am
    Yes, was able to find out , how to put background in both Redshift and Octane , especially if one wants to render both object and background in c4d itself , its helpful in motion/camera tracking.
    will post the details once i get home and logon to my work system
    Learn..Learn..Learn
  • Alex Anderson
    June 20, 2018 at 6:54 pm
    ok in Octane,
    1.create a normal c4d background object, assign any img or video png’s [octane meterial]
    2. in c4d render settings , select octane render, select ‘overwrite kernel settings’ tab
    3. select direct lighting option , and enable alpha channel and disable keep environment.
    4. in octane live viewer , select settings option and enable alpha channel and disable keep environment.
    In Redshift,
    just use Domelight and enable backplate option
    Learn..Learn..Learn
  • Karl Smith
    March 3, 2019 at 3:26 pm
    I have to thank you this, taken days to figure out how to do this in Octane.
