Activity Forums Adobe Photoshop Background Locked
  • Background Locked
    Posted by Toby Van kleeck on February 28, 2007 at 11:48 pm
    A friend sent me a bitmap file to modify and I can’t do anything with it. The only layer is the background and it is locked. The entire layer menu is blocked (I can’t highlight any options with the mouse). So basically I can’t do ANYTHING; not create a new layer, no applying effects…nothing. What’s wrong here? Any help is appreciated. Thanks!
    Tiffanib replied 19 years, 6 months ago 2 Members · 1 Reply
  • Tiffanib
    March 15, 2007 at 4:15 pm
    Usually bitmap files are in indexed colorspace, so you can’t work with layers.
    You’ll want to change it to RGB, and then in the layers palette, double click on the background layer to put it into an editable layer.
    At this point, you’ll end up saving it out as a jpg or gif – so if you want to get it back to bmp you have to flatten it, return it to indexed colorspace, and then save over the original.
    Tiffani B
