Activity Forums VEGAS Pro Background in DV, Chromakey in HD, Can Vegas do this?
  • Background in DV, Chromakey in HD, Can Vegas do this?
    Posted by Greg Roche on October 22, 2009 at 1:57 am
    I’ve shot all of my background footage in DV. I’m going to a studio to shoot the “green screen” in HD. I have Vegas 7, can the two video formats be merged and used in the same time-line within the same project?
    I could shoot the green screen in DV but the studio recommends that the chroma-key will work better if it is shot in HD.
    Any advice would be appreciated, Thanks!
    Greg Roche replied 16 years, 11 months ago 3 Members · 4 Replies
  • Jeremy Rasnic
    October 22, 2009 at 3:33 pm
    Yes, one of the many benefits to Vegas is that you can mix all kinds of footage on the timeline. This should work without issue as your output will be SD I assume. You will key in HD and then manipulate your keyed footage to fit against your SD background and then render to an SD format.
    j razz
    https://www.jrazzcreations.com
  • Norman Willis
    October 22, 2009 at 7:14 pm
    In a certain sense it also yields kind of a ‘depth of field’ effect too, since you will be sharper than the background.
    Not really, I know, but every little bit helps.
    Norman Willis
    http://www.nazareneisrael.org
  • Greg Roche
    October 23, 2009 at 12:40 am
    Jeremy-
    Yes I will be rendering as SD. Thanks so much for your advice, I was hoping that the HD/SD merge would be possible in Vegas 7.
  • Greg Roche
    October 23, 2009 at 12:41 am
    Norman-
    I never thought of that but you’re right, thanks for the post.
