Activity › Forums › Maxon Cinema 4D › BACKGROUND DISAPPEARS WHEN I DOLLY IN
  • BACKGROUND DISAPPEARS WHEN I DOLLY IN
    Posted by Sean Lloyd on September 8, 2022 at 7:46 am
    Hi All
    Hope this message finds you well…
    I am creating a video logo and I have a star-field background in the form of a physical sky. And it is fine, but when I dolly in an animation it disappears and turns into a dark blue, with no stars. And it doesn’t change when I take out the sky BG.
    I seems to coincide with when I am tilting up.
    It didn’t bother me that much, it was almost a nice transition, but as I am finishing, I don’t like it.
    So ultimately I would like to know why my sky is disappears and where this solid color is coming from, if anyone may have run into this problem.
    I’m on R-19
    Thanks in advance.
    Sean Lloyd replied 4 years ago 2 Members · 5 Replies
  • Andy Kiernan
    September 8, 2022 at 10:33 am
    is something intersecting with the camera maybe? some geo with a ‘glass’ material on or something?
  • Sean Lloyd
    September 8, 2022 at 9:07 pm
    I don’t think so, but I will check it out. It’s a good thought. There are a lot of glass panels in there.
    Thanks for the response, Andy. I really appreciate it…
  • Sean Lloyd
    September 9, 2022 at 9:04 am
    UPDATE: Andy, I took your advice and went thought different layers and oddly enough found it was disk layer that was actually on the ground and not obstructing the camera. I changed one of the material layers and it went away.
    Not exactly sure what is was doing, but thanks for the suggestion… It worked!
  • Andy Kiernan
    September 9, 2022 at 2:44 pm
    well, thats good news glad it helped, in one way or tuther!
  • Sean Lloyd
    September 12, 2022 at 2:58 am
    Definitely did.
    Was wondering if you’d know a way to do what the problem was (the background going solid) on purpose. I kind of like the effect. I just didn’t like the color and not having control of it. I was thinking of changing the depth of field, but it’s a 15mm lens so I don’t know if that would work.
    Any regardless. Thanks for your help.
