Activity Forums Adobe After Effects Background color
  • Background color
    Posted by Vid2face on February 14, 2006 at 3:32 pm
    I know this will sound like a retarded question…but I created a composition and added text and then figured I needed to change the color of the background but I can’t figure out where to change the color of the background. I’ve tried some things but nothing seems to work. Yes i’m new to the program ;o Thanks.
    Ryan Hill replied 20 years, 6 months ago 3 Members · 2 Replies
  • Todd Gillespie
    February 14, 2006 at 5:24 pm
    Usually it’s better to create another layer and use that as a background layer. Then if you need to change colors, you can use the layer settings.
    To change the background color of the comp is in your comp menu or -shift-command-b
    Good Luck,
    Todd at UCSB
    Television Production
  • Ryan Hill
    February 16, 2006 at 7:28 pm
    If you want to create a new layer for the background, you’ll want to “create a new solid.” You’ll get to pick a colour. If you want to change it later, it’s under the layer menu, I think as “layer properties” or “solid properties.”
