Activity Forums Boris FX Particle Illusion Background Blocking Particles
  • Background Blocking Particles
    Posted by Michael Sutherland on September 30, 2013 at 9:37 am
    I am working on a short film with six layers: the background image and then five different layers of particle effects. Somehow I changed a setting–and I don’t know which–that caused four of the layers to be blocked by the background. When I turn the background off, all five particle layers are visible. When I turn the background on, only one is visible. Every setting in the “Properties” sections of the layers and individual emitters are the same as before. I don’t know what setting I changed. Does someone know how to fix this?
    Michael Sutherland replied 12 years, 10 months ago 3 Members · 3 Replies
  • Terry Stephens
    September 30, 2013 at 1:37 pm
    It sounds to me like you may have accidently moved your background image above most of your other layers. I’m playing around with my new computer so I created a short video of what I think is wrong. If that is not the problem, You need Alan !
    https://reels.creativecow.net/film/wheres-my-emmiters
  • Alan Lorence
    September 30, 2013 at 4:00 pm
    I agree — you probably dragged a layer upward in the layers window (upper left window). Drag it down to the bottom or r-click and “move down” until it’s below everything.
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
  • Michael Sutherland
    October 1, 2013 at 8:58 am
    Yes, you’re exactly right. I did as you suggested and the effects are back! I knew it had to be something simple. I just didn’t know what it was.
