Activity Forums Adobe After Effects Background banding when compressed in AE?
  • Background banding when compressed in AE?
    Posted by Daniel De silva on February 10, 2015 at 9:46 am
    Hi Guys!
    I have a small issue, I added a background layer (72 dpi – JPEG) into my AE file, (both 1920-1080 res). When I go to render it at H.264 I receive banding on my background? Although when I export it from .ps there is already a slight bit of banding in the first place which I don’t want, but obviously not as much.
    What’s the easiest way to smooth it out?
    The video is for web.
    Dan.
    Daniel De silva replied 11 years, 6 months ago 2 Members · 5 Replies
  • Tero Ahlfors
    February 10, 2015 at 1:40 pm
    [Daniel De Silva] “What’s the easiest way to smooth it out?”
    Add a bit of noise.
  • Daniel De silva
    February 10, 2015 at 5:45 pm
    I’ve tried adding noise but it only reduces it slightly, (.8 noise amount). I don’t want to crank it up to far incase it begins to ruin the image.
  • Daniel De silva
    February 11, 2015 at 5:32 pm
    Hi Dave,
    I’m rendering out to H.264 through AE. I’ve managed to fix the banding problem! Most of it was due to the initial image.
    I have another question and since you seem to know what you’re talkingabout thought i’d post it to you!
    How do I transcode a 1080p video to a 720p video?
    Dan.
  • Daniel De silva
    February 11, 2015 at 6:04 pm
    ah ok great thanks. I tried re-sizing the comp to 720p which worked fine, but when i want to export it as a mp4 (presuming h.264 is best for web) it appears washed out :/ any advice?
  • Daniel De silva
    February 11, 2015 at 6:28 pm
    Which codec would be best for loseless quality? thanks! yeah i figured the nesting and resizing down to 720p, but when i render it to h.264 the colour quality is very washed out, when i render it in quicktime with a h.264 codec the colour image is good? Is what you described above the best way around this?
