Activity Forums Panasonic Cameras Back-up firewire recording simultaneously to P2
  • Back-up firewire recording simultaneously to P2
    Posted by Ron Mccoy on March 10, 2006 at 6:59 pm
    New HVX-200 user, reviewed some capture now FCP settings but wondering if you can record to Firewire Drive and P2 cards simutaneously?
    How will the new “Firstore” prodict achieve this?
    In the mean time can I recored to Firewire, or.. is that only on the Tape side of the camera?
    Real (Ron) McCoy
    Ron Shook replied 20 years, 6 months ago 6 Members · 9 Replies
  • 9 Replies
  • David Battistella
    March 10, 2006 at 7:44 pm
    How do you record to firewire?
    Do you mean you want to record to a hard drive and the P2 card at teh same time?
    David
    Peace and Love 🙂
  • David S.
    March 10, 2006 at 8:29 pm
    Currently, there are no outboard devices other than FCP 5.x through the firewire port that you can record to.
    FireStore and Cineporter are two outboard devices to permit recording directly via firewire – both to be released in the coming months.
    You cannot record to any firewire hard drive currently.
    You can transfer p2 footage to a self powered, not bus powered firewire device.
    Hope this helps
    David S.
  • Ron Mccoy
    March 10, 2006 at 8:44 pm
    Thanks for the reply, I’ve seen specs on the Cineporter using a P2 card connector and I have an earlier Firestore that worked
    extremely well with my DVX-100. I’ll learn to do the “P2 shuffle” until a better firewire drive solution becomes available.
    Is there any rationale to copy MXF files from P2 to Hard drive (faster) than importing P2 via FCP?
    When I tried the copy mode from P2 mode on my 17″ laptop then tried to import I gota file recognition problems, I thought I copies off all of the text files as well. Is it slower going through FCP since it’s dealinhg with a QT wrapper?
    Real (Ron) McCoy
  • Mike Schrengohst
    March 10, 2006 at 11:33 pm
    On my PB it is faster to import directly from P2 into FCP.
    I did a test and copied the P2 files to the HD and that seemed to
    take 2 -3 times as long. And then you would have to import them
    into FCP anyway. I back-up the QT files.
  • Barry Green
    March 11, 2006 at 11:40 am
    [David Saraceno] “Currently, there are no outboard devices other than FCP 5.x through the firewire port that you can record to.”
    Not correct. There’s the AJ-HD1200A DVCPRO-HD deck, there’s Avid XPress Pro HD and Media Composer systems, there’s Canopus Edius Broadcast, there’s the capability (for whatever reason) to use another HVX through firewire as a capture device, or there’s some new forthcoming P2 deck that you should be able to capture with. And a few weeks from now the FireStore should be available.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • David S.
    March 11, 2006 at 5:06 pm
    By outboard devices, I was referring to firestore/cineporter type devices, which was mentioned in the original post, Barry.
    Within that context, there are no outboard devices in HD format like the Firestore or Cineporter.
    David S.
  • Ron Shook
    March 11, 2006 at 10:58 pm
    David and everyone,
    [David Saraceno] “like the Firestore or Cineporter”
    I’m curious why no one ever mentions the CitiDisk Unit on this forum:
    https://www.proconusa.com/procon/product.asp?category%5Fname=HD+Digital+Video+Recorders&product%5Fid=CDHD%2D120
    Nearly half the price of Firestore or Cineporter, more compact and a variety of mounting options? I know that they had some real problems with their initial DV offering several years ago, but those seem to have been worked out nicely. I just talk to a guy who’s had two DV units for nearly two years with zero problems.
    Like the other units, it’s not quite out yet, but may beat both of the others to the starting line.
    Ron Shook
  • David S.
    March 11, 2006 at 11:03 pm
    [Ron Shook] “‘m curious why no one ever mentions the CitiDisk Unit on this forum:”
    Because despite it what appears, you can only use this to download footage from the cam or p2 card, not capture directly except for DV25, as I understand it.
    David S.
  • Ron Shook
    March 12, 2006 at 12:02 am
    David,
    [David Saraceno] “Because despite it what appears, you can only use this to download footage from the cam or p2 card, not capture directly except for DV25, as I understand it.”
    Zowie, kinda a problem, I’d say. We’ll see what they have to say and show at NAB.
    Ron Shook
