Activity › Forums › Adobe After Effects › back of rotating image
Posted by Stig Olsen on September 17, 2014 at 2:29 pmHi,
Is it possible to attach an image or another comp to the back side of an another image?
Like if I have an image rotating all the way around I want this new image on the back side to be visible.Stig
Stig Olsen replied 12 years ago 5 Members · 6 Replies -
Walter Soyka
September 17, 2014 at 3:18 pmDan Ebberts and expressions to the rescue:
https://www.motionscript.com/design-guide/invisible-facing-away.html
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Chris Brett
September 17, 2014 at 3:31 pmHi — if you dont fancy that all you have to do is this –
1 ) put reverse on a second layer 1 pixel back in z space
2 ) precompose front and back layers
3 ) rotate precomp — et voila ……..———————————————- chris —
Brian Charles
September 17, 2014 at 3:35 pm -
Chris Brett
September 17, 2014 at 3:36 pmHi — just remebered sometimes I keep the z space the same and anumate transparency at the point of transition — chris
John Cuevas
September 17, 2014 at 3:59 pmWish I’d seen this last week. Just completed a slide show presentation video, 600+ pictures rotating and this would of been a much better method than my approach. I should run all my projects by Dan before I start… 🙂
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
