Activity Forums Canon Cameras Back-focus on Canon XH A1
  • Back-focus on Canon XH A1
    Posted by Martin Gleeson on June 23, 2008 at 8:09 pm
    Hello,
    I have a Canon XH A1 camera. I usually zoom-in very close on a subject to manually focus. Then zoom back out the subject should crystal clear. However, I am noticing that this is not working. When I zoom back out, the subject which was in crisp focus is now out of focus. The backgound (a metre or more) seems to be in focus. Is this what they call a “back-focus” problem? If so, how do I correct it?
    Many thanks
    Martin
    Canon XH A1
    Search the Web
    Karl Thompson replied 18 years ago 3 Members · 2 Replies
  • Don Greening
    June 24, 2008 at 6:18 pm
    Typically, the backfocus adjustment on fixed Canon lenses like the A1 is a done electronically as opposed to a mechanical adjustment. If you think you have a backfocus issue with your camera your only option is to send it to Canon repair. They will mount the camera on a machine made for this purpose and do it right.
    – Don
  • Karl Thompson
    August 28, 2008 at 4:18 pm
    Hey man, I just bought 2 canon XH A1 for a production company that i’m building. I think I have the same problem that you have on both of my cameras. I was asked to do a shoot at 4:3 ratio and 60i. I noticed that my talent (person in front of cam) looked very soft and with out detail once I zoomed out. It looked the same way once imported to final cut. I was told by the canon people that it might be a back focus issue in which I would have to send these back to canon. My question to you is….were you able to get your problem resolved with the back focus or what ever was causing the problem? Was canon helpful in taking care of it? Or did you have to return your cameras?
    thanks.
    Karl Thompson
