Activity Forums Apple Final Cut Pro Legacy B Wav files working in Final Cut Pro Projects
  • B Wav files working in Final Cut Pro Projects
    Posted by Trevormac on November 13, 2006 at 8:00 am
    Is there anyway in which Final Cut Pro can import B wav audio files? B wav files have their associated Timecode imbedded in thier tracks . Apparently this can be done with final Cut, but after a couple of tests on my system it cannot pick up any time code details. I have Final Cut Version 5.0.4 with a G5 2.5 processor.
    Trevor
    Andreas_kiel replied 19 years, 10 months ago 6 Members · 6 Replies
  • Tom Wolsky
    November 13, 2006 at 1:04 pm
    I don’t believe that version of FCP supported Broadcast WAVE files. I don’t think that introduced until 5.1 or later.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Henninc
    November 13, 2006 at 1:36 pm
    hi there,
    you could use sebsky tools:
    https://www.dharmafilm.com/sebskytools/
    which is free…
    hope that helps,
    henning
  • Will Salley
    November 13, 2006 at 7:43 pm
    Tom is correct. 5.0.4 does not display BWF timecode. Sebsky tools works but it requires an extra step or two. If you plan on doing a lot of work with BWFs, it’s worth the $49 crossgrade (which runs out pretty soon I think) for FCP 5.1.2.
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
  • Anders Haavie
    November 15, 2006 at 7:01 pm
  • Andreas_kiel
    November 16, 2006 at 2:07 pm
    As the author of BWF2XML some notes here.
    It’s worth to spend the money for the upgrade to 5.1.2. But you should be aware of the way 5.1.2 does read the BWF time stamp.
    Like all other packages it looks for the “Samples Since Midnight”. Those samples will be converted to seconds and partial seconds by diving them thru the files sample rate. The seconds will be converted to TC based on the TC rate settings FCP had at launch time. This will work fine in most cases, it won’t work with DF timecodes since FCP internally doesn’t and never did support DF timecode for audio.
    The latter will lead to some problems; your files will run out of synch (though this is not a real problem with short clips, since you won’t notice the 0.1 percent drift) and you’ll get the wrong timecode.
    Regards
    Andreas
    Andreas Kiel
    Spherico
    Nelkenstr. 25
    D-76135 Karlsruhe
    Tel.: +49 (0)721 183 9753
    eFax: +1 650 897 8094
    eMail: kiel@spherico.com
    https://spherico.com/filmtools — some workflow tools for FCP
  • Andreas_kiel
    November 16, 2006 at 2:08 pm
    Regards
    Andreas
    Andreas Kiel
    Spherico
    Nelkenstr. 25
    D-76135 Karlsruhe
