Activity › Forums › Adobe After Effects › B-splines
B-splines
Posted by Matthew Beall on October 18, 2011 at 11:42 pmI used to do a lot of roto work, and b-splines really saved the day..
I can’t seem to find any way to do that in AE.. Am I looking in the wrong place?
Ben G unguren replied 14 years, 10 months ago 3 Members · 2 Replies -
Kevin Camp
October 19, 2011 at 8:22 pmyou can get bezier curves with masks or the pen tool, but i’ve not seen b-splines. there may be some third party effects that could give you b-splines, but i’ve not come across any….
i don’t think mocha does b-spline, but you might take a look at it… it comes bundled with ae and you can find several tutorial here on it.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Ben G unguren
October 21, 2011 at 4:13 pmThe term “B-Spline” can be a little confusing in AE-world. I like to call then “NURBS” (Non-Rational B-Spline curves), since that’s where I first came across the stuff, in Maya-land.
AE doesn’t have anything like that; it uses Bezier curves for everything (hence the confusion, as Bezier also begins with a B).
Mocha does have something similar to B-Splines, but it calles them “X-Splines” (it also has Bezier curves). If you prefer NURBS for rotoscoping, then MochaAE is the way to go. (Note that MochaAE comes with AE.)
Personally, I prefer to use NURBS-style rotoscoping for less-precise work, and Bezier curves for super-detailed stuff.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
