Activity › Forums › Apple Motion › B spline mask!
B spline mask!
Posted by Tarik Sykes on April 24, 2007 at 4:31 pmI have a rotating globe. It is a QT mov.! I masked it off and need to export the globe. I tried this and I have a blk. background not a trans. back.What am I doin wrong? Thanks!!!
Tarik Sykes replied 19 years, 5 months ago 2 Members · 8 Replies -
John Czerwinski
April 24, 2007 at 5:48 pmFile – export
under the Video/Audio tab
change compressor pull down to animationunder the Output tab
if the, “current project and canvas settings” is checked, uncheck it
and make sure Color pulltab has color + alphaexport file
Good Luck
John
Tarik Sykes
April 24, 2007 at 6:36 pmit still has the color back ground. i want it to have no background. It want it to be transparent!! Thank you…
Tarik Sykes
April 24, 2007 at 6:45 pmTransparent is workin in the preview next to canvas. But when I exort it, it has the blk. behind it not trans!!!!!!!
John Czerwinski
April 24, 2007 at 7:59 pmHow about this…File – Export – then under the export preset pull down, choose lossless + alpha movie.
BTW what program are you importing this file into?
Hopefully this will work
Good luck
John
Tarik Sykes
April 24, 2007 at 10:16 pmthat didn’t make the globe export with a transparent backgrnd! This is crazy I can’t figure it out!! I need to count to ten. I’m just goin to turn into a flash video and put on a web site. Once I mask it off it looks like it is right and then when i ex it isn’t right. What do I do….it was a istock globe video and then put into motion 2 for maskin!Thanks
Tarik Sykes
April 25, 2007 at 4:13 pmNot sure I was watchin a trainin vid on motion 2 and tried it all over and it worked.
Tarik Sykes
April 25, 2007 at 6:37 pmthe trainin vid was sayin what u said but I had the transparent on not the color on the canvas. So it had no alpha to take out. So I set it bak to color and it worked. I think him explaining made me put it back to color!Thanks!!!!!
