Activity › Forums › Apple Final Cut Pro Legacy › B-roll contact sheet for each reel
  • B-roll contact sheet for each reel
    Posted by Dan Mcguire on February 20, 2011 at 2:09 pm
    This is more a general edit question –
    I think it would make life much easier in the edit room to be able to consult a “contact sheet” of a particular reel – one 8.5×11 sheet that contains stills from a particular reel of footage – 1.5 inch thumbnails – perhaps 30 on a page – screen captured every 60 seconds or so, which would give me, at a glance, an idea of what is on the reel.
    Quicktime allows me to output an image sequence at one shot per second, but I need to output roughly one frame per minute. Then I will bring the stills into Iphoto and create a contact sheet. Is there an easy way to do this?
    Thanks in advance.
    DMCG
    Rafael Amador replied 15 years, 7 months ago 5 Members · 6 Replies
  • Rafael Amador
    February 20, 2011 at 2:20 pm
    [Dan McGuire] “Quicktime allows me to output an image sequence at one shot per second, but I need to output roughly one frame per minute”
    If you speed up the clip a 1800% (1440% if the footage is 24fps or 1500% if PAL) before exporting the still sequence, you get an still per minute.
    rafael
    http://www.nagavideo.com
  • Dan Mcguire
    February 20, 2011 at 2:39 pm
    It works, but the images are weird – interlaced? It seems to be a double exposure of 2-3 frames, so they are very blurred.
    Tried to output them as jpegs and tiffs, but same results.
    thanks
    DAN
  • Jeremy Garchow
    February 20, 2011 at 2:44 pm
    Turn off “frame blending” when adjusting the speed (command-j).
  • Steve Eisen
    February 20, 2011 at 3:38 pm
    View Browser items as large thumbnails and fill your screen (you can also set the poster frame). Use Grab to take a picture of your screen.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Mark Raudonis
    February 20, 2011 at 6:10 pm
    Or get “CATdv”. There’s a forum for it here on the cow.
    I keep one screen open in CATdv, and the other with FCP. I can search the whole universe of
    my media MUCH easier than I could in FCP. (Thumbnails and all).
    Try it. You’ll see.
    Mark
  • Rafael Amador
    February 21, 2011 at 4:31 am
    [Dan McGuire] “It works, but the images are weird – interlaced? It seems to be a double exposure of 2-3 frames, so they are very blurred”
    If the footage is Interlaced, of course the stills will show the interlacing.
    You may nest the speeded-up clip , drop an de-interlacer and set the sequence to NONE.
    rafael
