Activity Forums Adobe After Effects ayato 47
  • Posted by Dotan Baytman on April 12, 2005 at 11:48 am
    HEY everyone
    i have trouble with ayato 47 tutorial did anyone finish it?
    or can someone explain how to do the first steps?
    do i have to use illustrator to make the logo or can i use the create text function?
    thanx in advance
    Joe Chao replied 21 years, 5 months ago 3 Members · 4 Replies
  • Joe Chao
    April 12, 2005 at 1:50 pm
    you have to make the texts with the plugin:3D Invigorator.You can also creat the logo with text function,but your 2D logo might not to be as beautiful as the 3D logo greated by this plugin.
    If you have the plugin and you want to great the same effect as the one in ayato 47 ,you can make it by following the steps in the Example.27.
    Here is the link for example27:https://www.ayatoweb.com/ae_tips_e/ae27_e.html
    If you don’t have the plugin or you do not mind a 2D logo,just use the create text function,add your favourit action for your title,and then jump to step3.The first two steps have almost nothing to do with the followed steps.
    Wish you can understand my poor English,becaause English is not my first language.
  • Abie Silva
    April 12, 2005 at 1:57 pm
    He has a link at the bottom of the first step that you can follow to a similar project where he creates another logo animation; in this example he first creates the logo in illustrator.
  • Dotan Baytman
    April 12, 2005 at 9:40 pm
    Thanx for the reply
    yes i have the plugin
    but i can follow the settings he’s using
    how to do the animation of the text?
  • Joe Chao
    April 13, 2005 at 2:10 am
    open the 3D Invigorator setup window.Then select one of the shapes you want to animate from the downlist menu, add it into an set by click the SET downlist menu near by.Remember to add every letters into different sets,then close the setup window.Open the effect contral window.do you see the menu SETS?Now every set can contral a letter,set key frames for them and you can animate the letters now.
