Activity Forums Adobe After Effects Expressions axis/expression problem
  • axis/expression problem
    Posted by Pascal Greuter on February 13, 2007 at 2:37 pm
    Hi guys
    I have the following problem:
    I have two layers in a comp. When I move layer1 in the x axis, layer2 should be moved in the y axis and should get the same y value as layer 1. I tried the following expression on the position property of layer2:
    if (thisComp.layer(“layer1”).transform.position[0] == -102) {
    transform.position[1] == thisComp.layer(“layer1”).transform.position[1];
    But this gets me an error message saying something like “Expression result must have dimension 2 not 1 (sorry, my AE is in german language).
    Can anyone give me a tipp?
    thanks
    Cheers, Pascal
    Lloyd Alvarez replied 19 years, 6 months ago 3 Members · 5 Replies
  • Dan Ebberts
    February 13, 2007 at 3:16 pm
    The way you have it set up, I would think you’d want it like this:
    [value[0], thisComp.layer(“layer1”).transform.position[1]];
    }else{
    value;
    This leaves the layer in its position until layer1 has an x value of exactly -102, then it jumps to the same y value as layer1. Is that what you wanted?
    Dan
  • Pascal Greuter
    February 13, 2007 at 3:23 pm
    Hi Dan
    Yes, this is nearly what I was looking for. Many thanks!
    But it would be great when layer 2 moves to its new position instead of just jumping from the old to the new position. Can you also give me a hint on that?
    Pascal
  • Pascal Greuter
    February 13, 2007 at 4:26 pm
    Hi Dan
    This is nearly the way it should work. Thank you very much. But is it also possible, to move layer2 to its new position instead of jumping?
    Pascal
  • Dan Ebberts
    February 13, 2007 at 6:48 pm
    Possible, but not simple. I think you’d have to write some code that would start at the current comp time and loop backwards through the comp until you found the time when layer1 arrived a y = -102, then calculate where layer2 should be now based on how long it’s been, how fast you want the move to occur, and the distance to be traveled.
    Dan
  • Lloyd Alvarez
    February 13, 2007 at 7:12 pm
    depending on what direction you are traveling you could use linear:
    layer1position=thisComp.layer(“layer1”).transform.position;
    if (layer1position[0] <= -98 && layer1position[0] >= -102) {
    y=linear(layer1position[0],-102,-98,-102,value[1]);
    [value[0], y];
    }else{
    value;
    -Lloyd
