Activity › Forums › Maxon Cinema 4D › Axis point is not moving?
  • Axis point is not moving?
    Posted by Dan Dikemann on October 6, 2014 at 12:49 am
    Im trying to move the axis point on an object. I click the axis editing tool and try to move the axis. The axis seems to be stuck to the object. Ive tried it with other objects too like a normal cube and text and it still doesnt work. Ive done it before but its not working all the sudden?
    If you know the answer please reply. I use Cinema 4d R13.
    -Dan
    Brian Jones replied 11 years, 11 months ago 2 Members · 3 Replies
  • Brian Jones
    October 6, 2014 at 1:55 am
    The object has to be editable for the axis to be moveable. If it’s still parametric ( the standard cube, sphere etc) they are mathematically generated around the axis so if you move the axis the object moves. If you want to keep an object parametric put in a null and you can offset the object in the null and use it for the ‘axis’.
  • Dan Dikemann
    October 6, 2014 at 9:53 pm
    Oh… Ok thanks. How would you make an object editable to move the axis?
    -Dan
  • Brian Jones
    October 6, 2014 at 10:44 pm
    use the Make Editable command – it’s in a bunch of places, upper-left button in the viewport – you can right click on the object in the Object Manager and find it in the menu that pops up – it’s in the Mesh/Conversion menu – and the easiest is the shortcut, just press”c” with the object selected.
